My website URL is:
http://hkmail.occasional.ml/phpmail/result.php
What I’m seeing is:
I used PHP Mailer using SMTP, where The code is
<?php
date_default_timezone_set('Etc/UTC');
// Edit this path if PHPMailer is in a different location.
require 'PHPMailerAutoload.php' ;
$mail = new PHPMailer;
$mail->isSMTP();
* Server Configuration
$mail->Host = 'smtp.gmail.com'; // Which SMTP server to use.
$mail->Port = 587; // Which port to use, 587 is the default port for TLS security.
$mail->SMTPSecure = 'tls'; // Which security method to use. TLS is most secure.
$mail->SMTPAuth = true; // Whether you need to login. This is almost always required.
$mail->Username = "myid@gmail.com"; // Your Gmail address.
$mail->Password = "password"; // Your Gmail login password or App Specific Password.
* Message Configuration
$mail->setFrom('from@example.com', 'Awesome Website'); // Set the sender of the message.
$mail->addAddress('abc@gmail.com', 'John Doe'); // Set the recipient of the message.
$mail->Subject = 'PHPMailer GMail SMTP test'; // The subject of the message.
* Message Content - Choose simple text or HTML email
// Choose to send either a simple text email...
$mail->Body = 'This is a plain-text message body'; // Set a plain text body.
// ... or send an email with HTML.
//$mail->msgHTML(file_get_contents('contents.html'));
// Optional when using HTML: Set an alternative plain text message for email clients who prefer that.
//$mail->AltBody = 'This is a plain-text message body';
// Optional: attach a file
$mail->addAttachment('images/phpmailer_mini.png');
if ($mail->send()) {
$result= "Your message was sent successfully!";
} else {
$result="Mailer Error: " . $mail->ErrorInfo;
Gmail not sent. and error shown was
SMTP connect() failed. https://github.com/PHPMailer/PHPMailer/wiki/Troubleshooting
I’m using this software:
i am using PHPmailer using SMTP.
