PHPMailer Not working
Username
epiz_27284818
http://finoreminerals.com/
I am using PHP mailer still my mail is not going it is linked with the SMTP account
PFA THE CODE FOR THE SAME
<?php
if(isset($_POST['submit'])){
require "PHPMailer/PHPMailerAutoload.php";
function smtpmailer($to, $from, $from_name, $subject, $body)
    $mail = new PHPMailer();
    $mail->IsSMTP();
    $mail->SMTPAuth = true;
    $mail->SMTPSecure = 'ssl';
    $mail->Host = 'smtp.gmail.com';
    $mail->Port = 465;
    $mail->Username = 'videoeditsagehill@gmail.com';
    $mail->Password = '';
     //   $path = 'reseller.pdf';
    //   $mail->AddAttachment($path);
    $mail->IsHTML(true);
    $mail->From="noreply@gmail.com";
    $mail->FromName=$from_name;
    $mail->Sender=$from;
    $mail->AddReplyTo($from, $from_name);
    $mail->Subject = $subject;
    $mail->Body = $body;
    $mail->AddAddress($to);
    if(!$mail->Send())
        $error ="Please try Later, Error Occured while Processing...";
        echo $error;
    else
        $error = "Thanks You !! Your email is sent.";
        echo $error;
$to   = 'ssahilaagiwal@gmail.com';
$from = 'noreply@gmail.com';
$name = 'Inquiry ';
$subj = "New Inquiry from ".$_POST['name'];
$msg = "Cleint name-: ".$_POST['name']."<br><br> Cleint Email-: ".$_POST['email']."<br><br> Cleint msg-: ".$_POST['msg'];
$error=smtpmailer($to,$from, $name ,$subj, $msg);
Hi,
PHP Mailer works a bit differently with GMail;
i have done everything still not working, it works when on local host
Below $mail->IsSMTP(); please enter $mail->SMTPDebug = 2; rerun the script and share the response. Also you try to echo $error, is that defined?
here is the output
Try a few of these:
(Second answer)
Thanks worked for me!
No problem, happy for helping, Remember to mark the answer as solved.!
