while importing database phpmyadmin says acess denied
i did acess from my account
i was not given an option to input password and phpmyadmin is probably using something wrong
this is soooo frustrating
Welcome
Please share the full error message.
Until then, see this:
Many websites use MySQL databases to store information and settings. However, there are some reasons why the connection to the database may fail. This article describes some commonly seen error messages when connecting to a database, as well as some general tips to keep in mind when setting up a database connection.
Common Error Messages
Using MySQL is great, but the error message returned if there is an issue logging in to your database can be quite confusing. Here are some commonly seen erro…
If you login via the Control Panel, no username or password is needed.
If you use another phpMyAdmin or similar instance, it will not work
how do i increase max upload file size
i aded some code to htaacess but its still 10 mb that cannot load any backups
i read in forums that it is fixed permanently
how else can i migrate my site
i used all in one wp migrate since i have unsolved isues with phpmyadmin
i hope there wont be such isues with premium because its all stating to feel painfully hopless and frustrating
can i acess files uploaded via ftp to htaacess from wordpress?
You cannot change them on free hosting, your only option is to upgrade to premium
The way that both we and WordPress recomend:
If your website doesn’t use MySQL databases, moving your site is very easy. Simply upload all your files to the ‘htdocs’ folder on your hosting account with FTP or a file manager. If you have a PHP based website, check if it has any configuration files where a domain name or file path needs to be set. Update these values as required. If your website is using MySQL databases, you need to move the database contents as well and update the configuration of your website to use the database:
Backup…
Good website administration requires making backups of your account regularly and storing them somewhere safe yourself. You also need to download backups in order to migrate website to other hosting accounts.
InfinityFree does not create or store any backups of free hosting accounts. It’s your responsibility to regularly create backups, and to store them somewhere safely.
Backup your website files
The best way to backup your website files is by downloading them using a desktop FTP client.
O…
I am really not sure what you mean by this, can you explain furthure?
sorry i mean files in htdocs from wordpress
i figure i could upload via ftp then import from htdocs
tank you for quick response but still stuck
system
Closed
June 5, 2023, 4:53pm
#9
