unilog
January 20, 2023, 9:04pm
#1
Username: epiz_33355710
My site is connected to the database. But when I try to access at vista panel by clicking in phpmyadmin it presents a error message: ERR_TOO_MANY_REDIRECTS from Chrome. I have tried using Mozilla but still not able to access it.
Need Help!
unilog
January 21, 2023, 3:28am
#3
Still no changes. I cleared my browser cache, even logged in to Incognito mode. Reset my password from control panel.
KangJL
January 21, 2023, 3:37am
#4
Did you delete the cookie?
Something doesn’t look right with your screenshot.
The IP is not correct.
unilog
January 21, 2023, 4:06am
#5
Yes, i have reset the Browser. Which should delete my previous Cookie and cache.
The main problem. It used to redirects me to
http:///185.27.134.10/db_structure.php?db=epiz_33355710_ull
Whenever i press the phpmyadmin btn. But it was since last thursday it redirects me
http://[64:ff9b::b91b:860a]/db_structure.php?db=
Here.
I tried typing the IP address manually
again but it changes and cause ERR_TOO_MANY_REDIRECTS error in all my devices.
KangJL
January 21, 2023, 4:53am
#6
Not sure if it will do that
Do this then
Change the account password
Sometimes, if you change your password, the password isn’t processed correctly in the database server. You can force the password to be reset again by changing your hosting account password through the client area. Please make sure to use a different password initially, although you can change the password back to the original password you were using afterwards.
After changing the hosting account password, please wait for at least 15 minutes for the changes to go through the system. During this time, you may also want to clear cache and cookies to help make sure you will actually use the new password for phpMyAdmin.
unilog
January 21, 2023, 5:19am
#7
Let me try that and will give you an update.
unilog
January 21, 2023, 6:24am
#8
It worked today.
Although i tried resetting my pasword yesterday but it didn’t work.
Thanks Mr. KangJL
system
Closed
January 28, 2023, 6:47am
#10
