Hello !
I created my infinityfree account a few hours ago, and I still cannot access the phpmyadmin even tho I followed the troubleshoot guide found here: Unable to access phpMyAdmin - Docs - InfinityFree Forum
I cleared the cache and cookies from all the websites.
I tried the incognito mode.
I changed my password and waited for 1 hour.
and I still get the ERR_TOO_MANY_REDIRECTS page when accessing the phpadmin from the cpanel area.
This guide says that I should post a message if nothing worked, for staff to reset the database permissions.
Could you please help me ?
Thank you very much
if you’ve changed your password. you should wait for 15 minutes. else you can want admin to change permissions for you C:
Thank you for your reply.
Yes I have changed my password and waited for 1 hour. It has been 4 hours now and the phpmyadmin is still stuck in a redirect loop.
Can an admin help me ?
Thank you !
If you didn’t create a database, create one first before accessing the phpMyAdmin from that database’s page. However, I’m not an admin, but a Regular in no special group.
Thank you for the suggestion.
I actually aleady have created a DB. I also tried accessing phpmyadmin from it but it is the same result: I a stuck in a redirect loop.
Is there anything else I should try ?
thank you
Then wait for the Admin here to check for the database permissions if they are broken or not. Or clear cookies and cache.
Nervermind, I just deleted the account, created an new one, and now everything is working fine.
Thank you for your suggestions
Because of this post, that is a solution:
bn19199:
That means the topic can be closed, and no more off-topic discussions can go in the way.
i just wanted to hint them. but thank you
system
Closed
August 23, 2019, 6:25pm
12
