Please help me fix my site which says site CNT be reached
But now my site at joshdelight.ml is saying site is unreachable sometimes please I need a fix for my unique visitor to not get mad
Sometimes my website @www.joshdelight says site can’t be reached (unreachable site ) while after sometime it works.
It hasn’t said this for sometime but since when I installed a popup plugin it started saying that site can’t be reached and now I deleted the plugin but it still says site can’t be reached sometimes, pls help me fix my site ,i don’t want to lose my unique visitors
Pls help me decide what newsletter popup plugin would be suitable for an arimolite theme
Pls I need a response for my previous messages
I don’t know your WordPress theme and I don’t know every WordPress plugin by heart to tell which ones might be compatible. Your newsletter popup question is extremely specific, so I doubt anyone on this forum can help you with that (although I’d gladly be proven wrong). If your theme has some sort of support channel, you could ask it through there. But good old trial and error can work too.
And I don’t know why some Nigerian mobile ISPs are blocking access to your website. I explained to you last week why I can’t help you with this.
Pls how can I copy the google AdSense code in the points in the page of my website
If you use WordPress you need to install “Insert Headers and Footers” plugin, enable it, and then on the plugin settings put on the header the Google AdSense code and save the changes.
OK thanks I have installed the plugin
I entered the settings of the plugin and in the first section which says header I copied my AdSense code by site to the space box provided but pls can you tell me where to paste my AdSense code by ad unit in the plugin settings
And how long does it actually take for the ads to start showing
Pls help me fix my site at https://joshdelight.ml it says that my site is establishing server base error connection
Oh sorry now its working​:sweat_smile::sweat_smile:
That’s the outage we announced a few days ago:
I was denied permission by google to enable google ads in my site at https://joshdelight.ml pls can anybody tell me what the problem was with my site @ https://joshdelight.ml
Maybe someone at Google would know more about that?
If I had to guess though, I could see them deny your website because:
  • It’s using a free domain name.
  • It’s a blog with only three articles.
  • Two of these articles tell you how to get a service for free which you should probably be paying for, which seems a bit sketchy legally (IANAL).
But again, I don’t know Google’s policies by heart and I don’t know how they check websites.
Domain names are not the problem because I have made my research but thanks for your concern anyway​:v:t4::v:t4::metal:t3::metal:t3:
Pls how can I remove a cookie notice in my site, I mistakenly used two cookie notices instead of one and now I can’t get it out @ https://joshdelight.ml
Plus if I put a disclaimer in the article would the second problem be fixed
My site menu is stuck pls how can I fix it
A serious problem pls help
If I make new updates in my site @ https://joshdelight.ml through my admin dashboard,the changes doesn’t reflect to my website.
Pls I need help​:sneezing_face::sneezing_face::cold_sweat::cold_sweat::pray:t3::pray:t3::pray:t3:
