When you are seeking help our of our forums, you select category- Hosting Support. I trust this hosting admin, might be a template comes asking you to fill all your query in a systematic way? Yes, it comes… but what you do? You probably delete all the pre filled data and then write in your own words. Is this a better method to get the full support? Go ahead and describe all the details which were asked previously
Hi and welcome to the forum
That error is typically caused by scripts which require the InnoDB database storage engine, which is not available on free hosting. In other words, it’s not supported.
