So I pointed my domain https://ipassed.cf to my main website address w2xufuni.epizy.com using CNAME records, from cloudflare to get an SSL certificate, in additions to other benefits. But, I am being redirected to http://suspendeddomain.org/d/ when I enter https://ipassed.cf
My account and website are active and they are not closed.
Before you can point a domain name to the subdomain with the CNAME record, you need to add it to your account first. And to do that, you need to set it to the nameservers.
I am using cloudflare website(Not the one located in the cPanel), how am I supposed to change my NSs to infinityfree ones?
You mean I have to park my domain first, then change the NSs and point it using CNAME?
Yes, that’s the only way to add a domain to your account if you want to use external nameservers.
Hello I have the same problem with the test I’m doing. The domain is yo free with this url http://gestord.freecluster.eu/gestord/
Nobody is using it, so hits are almost none can you explain what is going on?
You calim to be free and I’m infinitely below the free limits.
Thank you for explaining.
Nobody is using it, so hits are almost nonecan you explain what is going on?
If your account is suspended, you must submit a review request. That’s the only way to get your account reactivated.
