when trying to install prestashop manually. it asked for a database server address, i had use the hostname but that did not work. so how do i find the database server address.
You can find it in cPanel > MySQL Databases. Inside it contains everything you need to know in order to make a database connection
The database server address is the database hostname. It should look like sql123.epizy.com. Did you try that already? If so, what did the Prestashop software say about that hostname?
fixed, seems like it was a problem with wrong password.
