I censored this time
Username epiz_30577281
ophinyx.ml
ophinyx.ml
Please try using GoGetSSL or ZeroSSL
I’ve always used let’s encrypt it’s never given me problems
That also looks like an older certificate. Can you try requesting a new one?
I don’t know what exactly you copied and pasted because you censored it (which is smart, it’s a private key after all), but I just tried to install your private key and it just worked.
Are you sure you copied and pasted the entire key, including the BEGIN PRIVATE KEY and END PRIVATE KEY lines with all the dashes?
