To stop displaying Directory Listing you need to add index file there, like index.html, index.php
Make sure you upload website files directly to the htdocs folder. So move all the files from the BizPage folder directly to the htdocs folder.
Also to disable it globally in your site, so your folders that doesn’t have any index file will be good.
Insert this code Options -Indexes
to your .htaccess
