Problem with Adminlte
epiz_30996916 http://fanthasia2022.epizy.com/
No site display
When I go to my site I only find files and nothing is displayed
I wanted to install Adminlte but nothing works and I can’t find any tutorial to help me. If you have the answer, please send it to me as soon as possible. Thank you very much !
Where did you upload files of AdminLTE? I only see some PHP files of Creative Tim
Looking at your site, I don’t see AdminLTE, but instead “Black Dashboard Laravel - Free Frontend Preset for Laravel”. The README.md file has installation instructions. And it’s very clear that this is not a HTML template, but instead an addon for the Laravel framework.
If you want to use a Laravel dashboard, you need to setup a Laravel site first and integrate the dashboard into it (again, following the instructions of the software).
I always thought AdminLTE was just a HTML template, but looking at the latest release it doesn’t seem to be the case. It just seems like it’s Javascript and CSS code without any HTML template code. So I have no idea how to build an actual dashboard with it.
You could just go to the preview site and copy the HTML from that site of course: AdminLTE 3 | Dashboard
