essouh
September 18, 2022, 12:56pm
#1
### Username (e.g. epiz_XXX) or Website URL
probleme avec htacces rewrite
pour un script php les pages ne sont pas creer example ajouter.html
essouh
September 18, 2022, 12:59pm
#2
redirection for 404 page ?
essouh
September 18, 2022, 2:00pm
#4
is not good
http://rank.great-site.net/ajouter.html
i think .htacces is blocked
.htaccess is not blocked, it is allowed here.
Can you please screenshot the contents of the htdocs folder from the file manager, and share your .htaccess file here?
Thanks!
1Truth
September 18, 2022, 2:22pm
#6
Je ne sais pas si on peut parle un autre langue qu’anglais ici mais tu peux vérifier que ton fichier htaccess
n’as pas autres commandes qu’empêche le creation de la page. S’il continue, obtiens une autre copie de le ficher htaccess
Translated by mod
I don’t know if we can speak another language than English here but you can check that your htaccess file does not have other commands that prevent the creation of the page. If it continues, get another copy of the htaccess file.
essouh
September 18, 2022, 2:27pm
#7
# A modifier si votre annuaire n'est pas Ă la racine de votre site
# Exemple 1 : si votre annuaire se trouve Ă l'adresse rank.great-site.net/annuaire vous devrez avoir pour RewriteBase : /annuaire/
# Exemple 2 : si votre annuaire se trouve Ă l'adresse rank.great-site.net vous devrez avoir pour RewriteBase : /
RewriteBase /Janembart-main/
RewriteRule ^ajouter.html index.php?act=ad [QSA,L]
RewriteRule ^ajouter2.html index.php?act=aj [QSA,L]
RewriteRule ^contact.html index.php?act=co [QSA,L]
RewriteRule ^contact2.html index.php?act=coj [QSA,L]
RewriteRule ^parametrer.html index.php?act=parampro [QSA,L]
RewriteRule ^recharger.html index.php?act=recharger [QSA,L]
RewriteRule ^accelerer.html index.php?act=accelerer [QSA,L]
RewriteRule ^merci.html index.php?act=merci [QSA,L]
RewriteRule ^boostmywebsite.html index.php?act=selfpro [QSA,L]
RewriteRule ^updatemywebsite.html index.php?act=selfproupdate [QSA,L]
RewriteRule ^websiteupdated.html index.php?act=selfproupdated [QSA,L]
RewriteRule ^search.html index.php?act=search [QSA,L]
RewriteRule ^nouveautes.html index.php?act=last [QSA,L]
RewriteRule ^index-amp.html index.php?amp=1 [QSA,L]
RewriteRule ^([a-z0-9\-]+)/([a-z0-9\-]+)/([0-9]+).([0-9]+)-([a-z0-9\-]+)-amp.html index.php?cat=$1§=$2&act=$3&id=$4&titre=$5&=1 [QSA,L]
RewriteRule ^([a-z0-9\-]+)/([a-z0-9\-]+)/([0-9]+).([0-9]+)-([a-z0-9\-]+).html index.php?cat=$1§=$2&act=$3&id=$4&titre=$5 [QSA,L]
RewriteRule ^([a-z0-9\-]+)/([0-9]+).([0-9]+)-([a-z0-9\-]+)-amp.html index.php?cat=$1&act=$2&id=$3§=$4&=1 [QSA,L]
RewriteRule ^([a-z0-9\-]+)/([0-9]+).([0-9]+)-([a-z0-9\-]+).html index.php?cat=$1&act=$2&id=$3§=$4 [QSA,L]
RewriteRule ^([0-9]+).([0-9]+)-([a-z0-9\-]+)-amp.html index.php?act=$1&id=$2&cat=$3&=1 [QSA,L]
RewriteRule ^([0-9]+).([0-9]+)-([a-z0-9\-]+).html index.php?act=$1&id=$2&cat=$3 [QSA,L]
#Flux RSS
RewriteRule ^sitemap/([a-z0-9\-]+)-([0-9]+).([a-z0-9\-]+).* index.php?act=$1&c=$2&format=$3 [QSA,L]
RewriteRule ^([a-z0-9\-]+)/([a-z0-9\-]+).xml index.php?act=$1&flux=$2 [QSA,L]
RewriteRule (.*) erreur.php
essouh
September 18, 2022, 2:28pm
#8
jai fais ca mais meme probleme
Translated by mod
I did that but same problem
1Truth
September 18, 2022, 2:35pm
#9
étrange… mais avec une nouvelle ficher .htaccess
il doit reinitialiser toutes des fichers…
dacc eh bien peut-êtes tu peux essayer recréer tes fichers un par un et trouver la problème s’il est avec juste un ficher ou le ficher .htaccess
Translated by mod
strange… but with a new .htaccess file it must reset all files… dacc well maybe you can try recreating your files one by one and find the problem if it is with just one file or the .htaccess file.
essouh
September 18, 2022, 3:08pm
#10
comment reinitialiser le fichier car jai la supprimer et maitre une de nv
meme probleme
Translated by mod
how to reset the file because I deleted it and master one of nv same problem
1Truth
September 18, 2022, 4:04pm
#11
Je pense que la meilleure décision est de reécrire ton ficher .htaccess
pour rewrite les fichers dans ton dossier racine. Aprés, écrit code pour inclure les fichers php que tu veux.
Comme ça:
<?php include $_SERVER['DOCUMENT_ROOT'] . '/ton_dossier/ton_ficher.php';
Translated by mod
I think the best decision is to rewrite your .htaccess file to rewrite the files in your root folder. Next, write code to include the php files you want. Like that:
Please use English here. Use an online translator if you need to.
It looks like you just deleted all your files from your website. Make sure you upload the files with the correct name and location
1Truth
September 18, 2022, 4:07pm
#13
Well I did say I was unsure but no one really responded here and it’s been an hour.
Is there a specific area for different languages or is the entire forum in English?
This entire forum is in English. It is posted in the guidelines.
essouh
September 18, 2022, 4:08pm
#15
thanx all problemes resolu
special thanx to digimag
1Truth
September 18, 2022, 4:09pm
#16
Apologies if this is off-topic, but please provide a link.
I can’t find the guidelines anywhere.
fbp110
September 18, 2022, 4:12pm
#17
1Truth
September 18, 2022, 4:14pm
#18
Thanks. My humblest suggestion would be to include English being compulsory in the guidelines (not telling mods how to run their forum, subject to correction).
system
Closed
September 25, 2022, 4:14pm
#19
