WordPress detected an error with its theme: functions.php.
Error details
An error of type E_COMPILE_ERROR was caused at line 256 of the file /home/vol15_6/epizy.com/epiz_27679780/htdocs/wp-content/themes/functions.php. Error message: require (): Failed opening required ‘/home/vol15_6/epizy.com/epiz_27679780/htdocs/wp-content/themes/IMAGES USED1 /…/ includes / custom-header.php’ (include_path = '. : / usr / share / pear / ')
WordPress version 5.7.1
Current theme: Corporatez-Ex (version 1.0.0)
Current plugin: (version)
PHP version 7.4.8
First make sure theme is indeed causing the issue by switching to default theme
Deactivating a broken theme
If a theme installation has been corrupted, the first thing to do is to switch to a different theme which does work.
If your WordPress admin area is still working, you can switch the theme from there. If that’s an option, changing the theme from there is the easiest option.
