Problema configurazione DNS
Ciao il mio username è epiz_30419514.
Vorrei aggiungere al mio profilo il dominio tldtrovaledifferenze.it
Il dominio è registrato su register.it e ho modificato 2 giorni fa i DNS inserendo
ns1.epizy.com
ns2.epizy.com
Se provo ad aggiungere un dominio sul mio account però mi esce la schermata caricata
Potreste risolvere il problema per cortesia
Hi my username is epiz_30419514.
I want to insert an addon domain called tldtrovaledifferenze.it.
The domain is on Register.it, and i have changed 2 days ago DNS in:
ns1.epizy.com
ns2.epizy.com
When i try to in insert the domain, this is the response
Can you fix the problem quickly please
Please note DNS changes can take up to 72 hours. You may also try removing the nameservers and adding them again.
If you try our Domain Checker tool, you’ll see that the nameservers for your domain name are currently ns1.register.it and ns2.register.it. You can also verify this with any other DNS lookup tool.
So please contact your domain provider about this, as it seems that the settings in their panel are not being applied to your domain name.
I checked on a common DNS lookup tool and i see the same as you. I wrote to register assistance and they told me:
*I’m sorry to inform you that the Italian Registration Authority doesn’t accept the DNS change you have submitted. *
*In order to verify the reason why your request failed, I kindly invite you to check the DNS configuration at the following link: *
*Verifica DNS | Registro .it *
**Please insert both the domain name and the DNS you would like to use and click on the red button “DNS Configuration Check”. **
I suggest you to forward the error message to your DNS hostmaster
The Dns check ive me this response
Unfortunately, I think you ran into this:
To understand.
My domain ends with .it
The domain is on register.it
If i modify the domain in .com i’ll solve the problem? Or i have to change one between register and infinity?
You’ll definitely need to change to a different extension if you want to host this domain with us. A .com domain is a great choice for this.
Even though the .com registry does not do any nameserver checks, your domain provider register.it might. I’d say it’s safe to try, but you can also register the domain with a known good provider like NameSilo.
