Nome account: epiz_30788863
Buon giorno, ho problemi per la connessione del dominio verso i vostri server
Ho modificato il dns come richiesto e ho il dominio registrato.
Potreste controllare?
Dominio: Wolf-agency.it
Please speak english. And likely you’re facing this:
in the domain registration site tells me that it points to you, can it be that I have to wait again?
for the moment I have waited a day
understood, thanks for the support
I will ask to check in the domain site
hello i have checked the dns but i have an error in your acceptance
I send you the screenshots
I have set the dns from the Italian Registration Authority site
and some procedures have failed
Can you help me?
Sorry, but hosting a .it domain is not possible here. See this:
Maybe you can still get a refund to purchase a regular TLD. A lot of ccTLDs don’t work here.
wackyblackie thanks for your help
I have not understood since I am at the first experience, what do you mean for
I currently have not bought anything on this site or the other one.
An example of a more regular TLD (a gTLD) is .com, .net, etc.
A ccTLD is what you rented from the Italian Registry: .it. Another example is .de, .eu, .io, etc.
If you can get a refund from the Italian Register, you should consider switching registries to another company, such as NameSilo and purchase a gTLD, they’re quite inexpensive. If you can’t, you’ll have to find another hosting provider, not on the Byet network.
thanks fo the support wackyblackie
Good evening, I bought the domain on Aruba
and it is this wolf-agencyitalia.com
it gives me the same error as the other domain that ended with .it
also this domain does not work with IF?
This looks like a registrar issue.
https://forum.infinityfree.net/search?q=aruba
Work with your registrar.
If they cannot resolve it, get a refund ASAP
Hi, the register told me this
can you give me the dns records?
in order to be able to point the domain wolf-agencyitalia.com towards the InfityFree provider, the DNS records must be provided for the pointing.
After having recovered them, I invite you to attach them in response to the following request for assistance in order to be able to provide you with support regarding their insertion.
you can send them the A record with the server IP from the client area.
I’m sorry but I can’t understand much
I’m a novice, could you explain better where to find them please?
Send them this:
Record Type A, Hostname = @ or wolf-agencyitalia.com, IPv4 Destination (Server IP) = (your server ip)
Your server IP will be in the client area and something like this under the account details section.
