I’m having problems to return json from MySQL database, when I print_r(array), the array that was returned from the query, it shows the data but when I try to convert it to json it shows nothing. I tested with xaamp and it works fine. I am using Insomnia to test GET requests.
$DB_HOST = 'sql207.epizy.com';
$DB_USER = 'epiz_25831176';
$DB_PASSWORD = 'Hidden';
$DB_NAME = 'epiz_25831176_hidden';
class DBI {
public static $connection;
public static function executeSQL(){
$myArray = array();
if($result = mysqli_query(DBI::$connection, "SELECT * FROM test")){
echo "Query was executed! \n";
if(mysqli_num_rows($result) > 0){
echo "Number of rows is greater than 0 \n";
while($row = mysqli_fetch_assoc($result)){
$myArray[] = $row;
} else {
echo "Number os rows is equal to 0 \n";
} else {
echo "Failed to execute the query! \n";
print_r($myArray);
return $myArray;
DBI::$connection = mysqli_connect($DB_HOST, $DB_USER, $DB_PASSWORD, $DB_NAME);
if(!DBI::$connection){
echo "Connection failed: ".mysqli_connect_error(). "\n";
} else {
echo "Connected to MySQL \n";
$myArray = DBI::executeSQL();
header('Content-Type: application/json');
echo json_encode($myArray, JSON_UNESCAPED_UNICODE | JSON_UNESCAPED_SLASHES);
