www.juniorprogramador.ga
O seu endereço WordPress está configurado para usar HTTPS, mas o certificado SSL parece estar inválido.
Fale com o seu provedor de hospedagem sobre resolver este problema de HTTPS para o seu site.
Gostaria de saber como resolver esse problema, desde já agredeço.
First of all, this is an English forum, please speak in English or use an online translator.
So with your issue, this problem is probably because of an incomplete SSL chain since there’s still no option to be able to install the root CA certificate here. Also I can see that you’ve already set up an SSL for your website so all should be fine, your visitors shouldn’t encounter any SSL related errors.
If you got that message from Wordpress’ health checker then you can ignore it.
