**What I’m seeing is: that when I use the ssl cert builder supplied with the website it does not recognize the cert when searched with https.
It shows a message:
## This site is not secure
This might mean that someone’s trying to fool you or steal any info you send to the server. You should close this site immediately.
cant use the ssl like how I wanted**
I’m using this software:Microsoft edge browser and the firefox browser
Hi there.
Use cloudflare. Activate Cloudflare in Cpanel. Then go to cloudflare website and log in with your email you use on infinityfree and your FTP server password.
In cloudflare, press SSL/TLS. There you can find SSL option. It’s free.
I have not got any other ssl provider’s SSL to work.
Do not set the SSL option to “Full (Strict)” unless you have a valid SSL certificate! Instead, set it to “Full”.
And, Cloudflare does not work with subdomains.
