Maybe you should bought a VPS server? Then, you can enable it on your own server.
Youâre quite quick to consider something a but there.
Looking at the error message, it seems that this software requires at least MySQL 5.7 or newer to work. Our servers are still MySQL 5.6. Thatâs not a âbugâ, because our choice of MySQL 5.6 is intentional, and MySQL 5.6 is still being supported. Weâll probably upgrade MySQL at some point in the future, and youâll be able to run this software when we do.
Ask the developer why putenv is needed at all? If itâs to run system commands, then you can be pretty sure that most paid hosting wonât work. If itâs to use .env files for configuration, then the developer made a mistake and the function isnât necessary at all.
