Putenv PHP Extension Is Required
A script I’m trying to install says “Putenv PHP Extension Is Required. This PHP function is required. You’ll need to enable it or ask your hosting provider to do it for you to continue the installation.”
How do I go about asking InfinityFree to enable it for me? I understand they don’t give support for scripts but I’m not asking for help with the script. I just need the Putenv PHP Extension enabled.
Would it be possible or no? Any help or answer would be greatly appreciated.
Thanks.
Never mind. It looks like it will never be enabled. That’s too bad. Thanks anyway.
Putenv PHP Extension Is Required - Hosting Support - InfinityFree Forum
The admin can close this topic.
