Question 1: If you only create 1 file in your website and it is a php, when visited it will run the code [[“echo ‘hello’;”]], when a somebody visits the page, will your daily hit be used? and/or how much will it take up.
Question 2: When you send a request to that 1 php file with json encoded data, will a daily hit be used, and/or how much will be used.
A hit is a simply request to a file on your website, which can be a HTML or PHP page, an image, a CSS file or something else.
If a visitor loads a single page which has two CSS files, three Javascript files and five images, that will generate a total of 11 hits to load that page. If your website code makes any requests to your website in the background (like with a chat script), these requests count towards your hits usage as well.
The hits limit is measured by how many STATIC files are being loaded per client. If one person goes to your home page, and has to load 3 JS & CSS files, that counts as 3 hits. If there are no static files being loaded, the hits won’t increase.
