Dear sir/madam, im trying to setup a fresh website. flyhighquality.ga
The first thing im doing is trying to get the SSL working through cloudflare. This all went smooth, nameservers changed etc. But then after installing the Really Simple SSL plugin on the wordpress website, it started giving an error. I tried debugging and it gave the following. Hopefully you know exactly how to fix this.
Options:
WordPress redirect
Mixed content fixer
SERVER: apache
SSL is enabled for this site
** Detecting configuration **
plugin version: 3.2.3
Already on SSL, start detecting configuration
SSL type: LOADBALANCER
** Configuring SSL **
testing htaccess rules…
test page url, enter in browser to check manually: https://flyhighquality.ga/wp-content/plugins/really-simple-ssl/testssl/loadbalancer/ssl-test-page.html
htaccess rules test failed with error: cURL error 60: SSL certificate problem: self signed certificate
checking if .htaccess can or should be edited…
.htaccess does not contain default Really Simple SSL redirect
retrieving redirect rules
converting siteurl and homeurl to https
Could not connect to website
For me it redirects too many times (aka gives me an ERR_TOO_MANY_REDIRECTS error). From the Cloudflare dashboard select the domain you precedently added, then click on “Crypto” and change the SSL option from “Flexible” to “Full”.
I had used Really Simple SSL and i know why TOO MANY REDIRECTS error is being caused. The main reason for that is you are using both wordpress redirect and .htaccess redirect. Try using only one redirect at a time from Really Simple SSL Settings.
Warning: Your verification URL is not returning the correct contents to our verification servers. The URL looks like it is blocking bots and which inadvertently blocks our servers from receiving the correct content. Contact your host, a professional developer or admin for further help with fixing it.
Also, using Cloudflare doesn’t work with subdomains. So you need to buy a domain or use a free domain from Freenom that you need to point to the nameservers ns1.byet.org and ns2.byet.org and add on a hosting account here on InfinityFree.
The .tk domains are banned from this hosting due to abuse. From Freenom, pick any other extension, except the .tk one, if you really want a free domain.
ive got the .ga domain and it isn’t working either. Is that because of the same reason? (See the really simple ssl debug ive posted above in the first post)
Leave that self-signed certificate thing alone on Really Simple SSL. That’s normal, just because there is no signed certificate on the server, but on Cloudflare’s reverse proxy system there is one.
