Recieving email problem
Hi,
I have got a problem receiving emails on roundcube, I can send emails without any problems but not receiving.
My MX records are set correctly as instructed on the warning message, Warning message states that MX records should be set to mx.epizy.com and that’s what i did with priority of 10.
problem is i have another MX record for a ygdkgkbi.epizy.com domain and mx.byetcluster.com record that i can’t delete.
Can someone tell me what to do to recieve emails properly?
My domain is michaelaziz.ml
and e-mail is HI@michaelaziz.ml
Thanks.
Your domain is using Cloudflare’s nameservers, which means you need to use Cloudflare’s DNS controls instead of the ones in your control panel. The DNS controls in the control panel only work if your domain is pointing to the InfinityFree nameservers.
So, how can i configure email setting from cloudflare? or should i just disable cloudflare and redirect nameservers to infinityfree?
No, you can just add the MX record through Cloudflare’s DNS controls.
Is this right?
@MichaelWAziz said:
Imgur: The magic of the Internet
Is this right?
Yep, that looks like the right setting.
