ww01.exampledomain.bargains currently does not have any sponsors for you.
Only happens when I have wordpress installed via softaculous.
Redirects to a ww01. domain instead of www.
Then presents the error “No Sponsors”
When I remove wordpress and restore index.html it goes away.
I don’t understand, what does this screenshot show/imply?
Also, I find it odd that I can still navigate to the old (renamed) index.html just fine indicating it’s at least not a DNS caching thing, it’s only when I install wordpress that this issue arises? https://www.cbd.bargains/index.html_
I see. What website/tool are you using to find that information?
I don’t know what fixed it in the end, but it seems to be mostly working now. I tried a combination of removing the “addon domain”, addding it back, reissuing a new Let’s Encrypt SSL certificate, and installing it, and reinstalling wordpress.
However, now I am having a new issue, when I try to modify a widget under Appearance>Widgets I get this
I can’t win it seems, perhaps I will try something other than wordpress and see how that works out any better… Thanks for the information.
