My Zone is redirected to URL: http://suspendeddomain.org/a/ but my site is (I believe) fine. Why is my CDN having this issue? @Admin
Here’s my CNAME from KeyCDN cdn2-cb33.kxcdn.com
Thanks later
Thanks later
@mauwiks said:
My Zone is redirected to URL: http://suspendeddomain.org/a/ but my site is (I believe) fine. Why is my CDN having this issue? @AdminHere’s my CNAME from KeyCDN cdn2-cb33.kxcdn.com
Thanks later
Could you share your site URL?
And also, when you used this CDN, did you add your account’s main domain as CNAME record?
https://kindtechgroup.net (main domain)
I haven’t setup any CNAME record yet since I’m still testing the service. Actually, it worked fine at the start but just this earlier, it’s ruined after I tried to activate the Let’s Encrypt SSL they were offering on the Advanced Pull Option. @ChrisPAR
@mauwiks said:
https://kindtechgroup.net (main domain)I haven’t setup any CNAME record yet since I’m still testing the service. Actually, it worked fine at the start but just this earlier, it’s ruined after I tried to activate the Let’s Encrypt SSL they were offering on the Advanced Pull Option. @ChrisPAR
Seems like the error is fixed now; Maybe they had suspended your main domain, I was not able to access it at the time I answered.
Now the other link you posted from KeyCDN just gives 403 error.
Nothing works from here.
Actually I deleted my zone and created a new one. After that, it didn’t fix the problem. It still redirects to suspendeddomain.org with advertisements from iFastNet.
My main domain is not a problem. The Zone with KEYCDN is. Haven’t slept enough troubleshooting that one last night from here. I’ll try again one more time… :neutral:
What Mixed Content do you mean? If you seen 403 Error, maybe because I was editing the zone and let it propagate at the time you have checked it.
I’m just wondering why it redirects to iFastNet. Please take a look at it @Admin
@mauwiks said:
Here’s the new CNAME from KEYCDN:
cdn-ce03.kxcdn.com
This one works fine from my end.
What kind of URL is http://cdn-ce03.kxcdn.com even. Is it some kind of CDN proxy to your own website?
I don’t think that it’s possible to do what you’re trying to do here. I suspect KeyCDN forwards the domain you enter to the server. However, our hosting servers don’t know the domain cdn-ce03.kxcdn.com, so they don’t know which website to serve on it (a problem you would have with any web hosting provider).
Normally, the way to fix this would be to make sure that the CDN domain is also on the hosting server. But you can’t add they KeyCDN domains here and you can’t add a subdomain to your domain and set up a CNAME record for it at the same time.
It might be possible to cobble something together with third party nameservers. But if I were you, I would avoid the headache and just use Cloudflare.
It’s a CDN from KeyCDN. Actually, I just figure it out… I need to turn off the Orange Cloud on CloudFlare.
Here’s the link: https://www.keycdn.com/support/how-to-create-a-cname-in-cloudflare/
