Redirects why???
Why is my pages apended with eg. ?_=1527342949826&i=2
Then because Im loading content pages from a folder, the page opens in the folder direct.
This seems worse than advertisements being displayed
Please check the KB before you ask anything:Why do I see ?i=1 at the end of a URL - Docs - InfinityFree Forum
If you want to disable it, you should use the Integrated CloudFlare with HTTPS.
Also, you say:
No it isn’t! Try a host which displays unlimited ads on your site without permission and then say that this is worst!
At least here you can disable this while on the other hosting companies you can’t disable their ads!
I even posted a discussion, hope I help: Disabling the ?i=1 Problem {SOLVED} - Informal - InfinityFree Forum
Also, you say:
I see, cloudflare will not help with live updates from my server to webhost
Also, you say:
You can disable Caching, if that’s what you mean so that you do live updates.
Four seemingly irrelevant characters are being added to your URL. No InfinityFree branding or content of any kind are injected into your page. Most mobile browsers don’t show the URL suffixes to begin with. Can you elaborate on why you think this this is worse than popups, in-text ads, auto playing videos or banners shifting your website content?
Why did I say four when your text is longer? Because only the &i=2 parameter is added by us, the ?_=1527342949826 is not caused by anything from the hosting itself as far as I know.
