Additional information: i have 2 domains hosting through you, namely www.kreater.co.in and www.kreater.epizy.com
i uploaded same script on both the websites via ftp and were successfully uploaded too!
when i redirected to installers in them that is www.kreater.epizy.com/ninjamediascript2/install.php
it shows here that mcrypt library is available and is also successfully being installed in the domain (i mean the script)
but for the same, when i go to my main domain that is www.kreater.co.in and redirect to same installer here that is www.kreater.co.in/install.php , it shows here that Mcrypt library is not available here and also doesn’t exceeds further. when i tried calling developer, they said contact your hosting company.
please see to the same that why Mcrypt library is available in one and why not in the other for the same. Please try to enable Mcrypt library in www.kreater.co.in as if the websites gains a few followers, i shall upgrade to the premium ones for sure.
please do the best from your side and enable it soon in my hosting.
thanks
mcrypt was removed from PHP in version 7.2, because it’s outdated and insecure. We run PHP 7.3, so mcrypt is no longer available as an extension. You can/should use Sodium or OpenSSL instead: PHP: Introduction - Manual
If you really, really need to use mcrypt, you can downgrade your account to PHP 5.6. But know that you’re living on borrowed time: mcrypt and php 5 are bad and there will come a time where you can’t use them anymore.
Please contact your developer and let them know about this, and suggest that if they are still using mcrypt, they should probably not be writing their own cryptography code in the first place.
The easiest way is to create a PHP info file. Simply create a new file with the .php extension and the contents <?php phpinfo(); and open that in your browser. That page will show all modules and settings enabled for your account right now.
