@OrcaFrost
Do you mean removing the .php in the end?
I am not so sure if the thing you ask, if there is any way, but since your website has only the index.php that means that this is what your visitors will see when they visit your website’s raw address.
.htaccess file
Disable Directory Listings in this Directory and Subdirectories
This will hide the files from the public unless they know direct URLs Options -Indexes
@OrcaFrost said:
I’m using codeigniter framework for my site.
The url of the framework is
http://{hostname}/index.php/{class}/{function} .
In local, we have php -S {hostname}:{port} where the url will be changed into
http://{hostname}:{port}/{class}/{function} .
The latter will prevent access to directories either, since the only accessed file is index.php.
Is there any method to implement this feature in Infinityfree?
Youre going to need to do some homework on .htaccess because .htaccess will control your entire URL methodologies. So, in order to design your .htaccess to your own personal needs youre going to have to figure that out on your own.
