Rewriting URL without redirecting issue
Hello,
I am trying to rewrite the URL without redirecting to simulate subdomains.
That is to say:
Rule 1. rewrite www.yoga-kids.net/whatever/ by whatever.yoga-kids.net
At the same time I want to have yoga-kids.net rewritten to www.yoga-kids.net. (I manage to have this easy piece work!)
Without rule 1 (with or without the strikethrough line), here is the htaccess:
Options +FollowSymLinks
RewriteEngine On
Redirect non-www to www:
RewriteCond %{HTTP_HOST} !^www\. [NC]
RewriteRule ^(.*)$ http://www.%{HTTP_HOST}/$1 [R=301,L]
Prevent viewing of .htaccess file
<Files .htaccess>
order allow,deny
deny from all
#Prevent directory listings
Options All -Indexes
I tried to have rule 1 added through:
RewriteEngine On
Redirect fake suddomains to folders
RewriteCond %{REQUEST_URI} !^www.* [NC]
RewriteCond %{HTTP_HOST} ^([^.]+).yoga-kids.net$ [NC]
RewriteCond %{REQUEST_URI} !%1
RewriteRule ^(.*)$ /%1/$1 [L]
#Prevent viewing of .htaccess file
<Files .htaccess>
order allow,deny
deny from all
But it does not work. 500 Error.
I have been looping on this issue but can’t figure out how to fix it. There might be a loop somewhere…
Could you help me?
Thank you,
Chris.
I’m not entirely sure what this means. Are you trying to alias blog.example.com to the content of example.com/blog/ ?
I’m sorry, but that is not possible on free hosting. On here, every subdomain get it’s own folder. And it’s not possible to use .htaccess rules to include the content from one website into another (not just on our hosting, but in general).
The only way to duplicate content on blog.example.com and example.com/blog/, it to manually copy the files into blog.example.com/htdocs/ and example.com/htdocs/blog/.
Hello admin,
Yes that's what I am trying to do: aliasing blog.example.com to the contents of example.com/blog/.
Too bas it is not available on InfinityFree free hosting.
Duplicating contents is not a proper solution...
Is this decision from InfinityFree subject to be reassessed?
Thank you,
Chris.
ChrisL said:
Hello admin,
Thank you,
Chris.
I can't say anything for sure, but I don't see any reason why we would change this behavior.
Most people specifically DON'T want to have their subdomains as subdirectories. Search engines tend to penalize your website if you've duplicated content on multiple domains, which means having the site accessible in both ways is usually bad. Additionally, using subdirectories tends to cause unintended side effects with .htaccess rules, and make it harder to properly isolate seperate domains for security.
I think I understand what you want and why you want this, but your setup is quite exceptional.
The best solution would be to have this configurable so you can decide for yourself which domain is linked to which directory. Which is already possible with premium hosting. But I personally don't see this feature brought to free hosting any time soon.
OK. Thanks for your answer.
Chris.
