Hello we are using infinityfree for a project for school. And we would like to know if it is possible to cancel the subscription monthly. Because we would like to use it only during the course and afterwards we no longer need it. So if we need to pay even after the course is done we will keep using the free version.
Do you mean to use temporary hosting? If you want to use it then use it but if not then it is not used?
You can use it continuously on this free hosting because there is no billing period, even though you have no project for school and please note that hosting with a temporary subscription will make it troublesome because you have to upload it again if the subscription ends if you use paid hosting, because the data will be deleted and will not be stored on the server
If you want to know more about iFastNet’s premium hosting, maybe you should ask iFastNet directly, instead of a partner who happens to show affiliate offers for them?
But to answer your question: if you choose the monthly billing option with iFastNet, it really means you are on a monthly plan, which you can cancel at any month.
