שלום איך אני הופך את האתר https?
Hi and welcome to this forum! Please note that this is an English community forum, and so you must speak in English, or at least provide machine translation of the content. Since you didn’t do both, I used Google Translate to do the translation:
You need to install a SSL certificate on your hosting account, and to do that you can use either the “SSL Certificates” section of the Client Area or Cloudflare’s Flexible mode. After installing the SSL certificate, you have to make sure your site redirects to HTTPS. If it doesn’t this article should help you.
Where in the hospitality account?
I think you meant host account. But go to SSL certificates section in the client area. Note that subdomains are not supported.
