It seems like something is misconfigured somewhere. Possibly your DNS entries or control panel settings? Try getting it to work on http:// first with no Cloudflare or SSL. Then, after you confirm that DNS has propagated, and the site works, then try adding in your other stuff.
i used the auto install feature. it had been working perfectly for weeks until i checked it today and it’s down.
i know nothing about DNS servers. as a matter of fact, i don’t know what to do right now. i am seated behind my computer screen hoping that a miracle happens.
There appears to be something weird going on here.
When I query the nameservers for an IP address, I get 185.27.134.176, which appears to be a free hosting IP, but it’s throwing an error I have never seen before.
Running a WHOIS lookup for the domain, I see the correct nameservers, and that it was not updated recently, but your registrar seems to not be returning the correct nameservers when a request it made.
The first half is probably an issue with the hosting service, and Admin will have to take a look at that. The second half may be a problem with your registrar, or just a weird side-effect from the first issue.
You will have to wait for Admin for additional help with this, but hopefully I missed something that would make this an easy fix.
