I`ve problem with site
http://drjaroslawcwikla-teologbiblijny.epizy.com/
Over 5 minutes its down. Work 2-3 minuts and again it
s down.
It`s a temporary global problem, or something is bad with my account?
s down.
The IP your website is on is currently offline due to load balancing (or DDoS) issues. So you should wait until it stabilizes itself.
hey i encountered this problem too on one of my account that hosted ini hosting volume 6_5,
in which hosting volume your account is?
I also have problems accessing my website. You are not the only one facing this problem.
Where i can check that?
You can find it on âAccount Detailsâ that can be found on your Control Panel
But what do you mean? PHP version or what? I canât find anything else
Look at âAccount Detailsâ label on the right side bar if youâre on desktop view
Oh sorry. Iâve 5_5
Hosting Volume vol5_5
So what now can I do?
There seems to be some server difficulties, donât know more about it though.
