my website even after acquiring the free ssl certificate my site is still not secure
Are you using wordpress?Try to install again your site using Softaculous and put https. Note that you will have to chose the directory then go to Cloudflare and put “Flexible”
i am not using cloudflare for the free ssl.
i am using in built infinity free ssl
You can also go to Wordpress settings and put HTTPS
Well, I recommend you cloudflare because Infinityfree doesn’t work, make sure that you don’t have a subdomain
@Dancan, I checked and your website contains Resources that are served by non-secure URLs. You have to fix it by using a mixed content fixer like Really Simple SSL. Just install it like a normal plugin, enable it and click on “Go ahead, activate SSL!”. Like so you fix the mixed content errors.
i did but still not working
Yes, I never thought that before…
Really Simple SSL is a plugin from Wordpress, try to install it.
To get it, just go to cloudflare, register with simple steps and select SSL and put flexible and always use HTTPS
i already installed it
You replied to the wrong person. Also, I don’t use Cloudflare for the SSL anymore; I own my server stack and so install Let’s Encrypt SSL without anything else used; just an ACME client like Certbot on the server itself. I only use Cloudflare as DNS service only.
Use HTTP rewrite on your Cloudfare SSL/TLS dashboard.
You’re not using Cloudfare Certificate, and you’re using Let’s encrypt Authority
Maybe this could help you.
Hello @Dancan I tried to enter your website but I don’t see anything, Google Chrome just give me error.
About HTTPS: Using Cloudflare is just a suggestion but I recommend it because it is easy to put a SSL certificate there.
