Hello!
My website URL is:
ophlite.ml
What I’m seeing is:
When I’m try to open http://ophlite.ml/ and https://ophlite.ml/ from various devices I get:
Google Chrome: ERR_CONNECTION_TIMED_OUT
Microsoft Edge: INET_E_RESOURCE_NOT_FOUND
Firefox: The connection has timed out
Tor Browser: no problems
The same with mobile browsers
http://ophlite.epizy.com/ - no problems
I’m using this software:
I do not use CMS.
Freenom nameservers are changed to Cloudflare nameservers.
Cloudflare automatically added A records with target IP address.
Free SSL certificate from InfinityFree created 2020-01-22 17:08:22.
Cloudflare SSL/TLS encryption mode is “Full”.
Additional information:
- There were no any problems in mode “DNS only”.
- 2020-01-23T11:00:00Z) I turned on “Proxied” Cloudflare and the site has stopped working.
- I did not configure SSL certificate from Cloudflare.
- 2020-01-24T14:00:00Z I cleared the browser cache, purge public and local DNS cache.
- OpenDNS showed IP 104.28.2.105
- SSL Checker:
- ophlite.ml resolves to 104.28.3.105
- Server Type: cloudflare
- The certificate should be trusted by all major web browsers (all the correct intermediate certificates are installed).
- The certificate will expire in 258 days.
- The hostname (ophlite.ml) is correctly listed in the certificate.
What can I do? Will this help in my case?
https://infinityfree.net/support/cloudflare-shows-error-1016-origin-dns-error/
You can try to fix the records manually by first deleting all DNS records currently in Cloudflare. Then, you’ll want to add the following DNS records:
CNAME
record with source@
and the target being your account’s main domain.CNAME
record with sourcewww
and target@
Or wait more?
