https://www.scratchblox-forums.epizy.com/
This wasn’t happening earlier today, and I checked my cPanel, and it doesn’t seem like any of my limits went over.
Same problem here! Does anyone know how to fix it?
Thanks, much appreciated.
If multiple users are experiencing this issue, its mot likely a global issue. Please wait for more information.
Hello @Turtle84375 and @babypirate,
It looks like website IP 185.27.134.112 is currently down, @Admin should be able to provide more information about why and when it will come back online soon.
Ah, I figured as much, after looking at other similar posts.
Thanks for the information!
I got a similar problem I think it may be some kind of outage.
Other people have this problem so I know it’s not Cloudflare.
hello the ip: 185.27.134.113 I don’t think it works either.
my website is: rmesystems.com
and it does not work
Yeah, it’s definitely something with the IP, I can’t say for certain, but maybe it’s affecting all of 185.27.134.XXX? I could be wrong.
@babypirate @Marius_Sheppard @RME_Systems The issue has been resolved, at least on my end! My site is now working again. If you had the issue, you may want to check again.
You are right !! I can confirm everything is working fine now.
Same problem here!
Edited by the moderator
This post was written the day before but was awaiting approval,
hence if one reads and thinks it is new - please ignore it.
