Site.pro error
Website URL
janusz.000.pe
FTP connection error
Error: Builder could not connect to hosting server. Please check hosting firewall. It must allow FTP connections from builder serve
I can access file manager from my account tho. idk
We don’t usually block specific IPs from accessing our FTP server, but there is a brute force protection and rate limiting in place that will block if you try to login with invalid credentials too many times. It’s possible that the Site.pro builder server hit one of those limits.
But that should just fix itself after an hour or so. Did the issue persist for you for more than an hour?
Yea its been happening for like 2 hours
solved
