Sitemap wont fetch
https://www.nginike.ga
I seem to be doing something wrong
i did uncheck the tikbox in wp
7
how can I change the robot file ATM it is like this
11111
ALSO, my files seem weird in my file manager as there is nothing in m htdocs but inside my folder called nginike.ga the other folder is empty the .epizy one and the normal htdocs is this correct?
is everything right
I added on domain I never pointed a domain
Does one of the many, many other topics about this have an answer?
https://forum.infinityfree.net/search?q=sitemap%20order%3Alatest
you think i haven’t tried that
I think Admin has linked to topics that they don’t have clear point or answers, but however if you really had tried it, you would find out topics like that (with just googling)
https://support.google.com/webmasters/thread/65722545?hl=en&msgid=65722545
Yet you do think that by asking the same question once again will get you more answers this time?
@kingstalker
you can try this too (for some it works)
https://counsellr.com/couldnt-fetch-sitemap-error-on-google-search-console-solved/
thank you
sadly it did not work for me
YW
This is a fairly common problem on GSC
When I last tested your sitemap google could read it (access)
btw. for some people it just worked after 2 months of waiting
Couldn’t fetch : The sitemap could not be fetched for some reason. To learn why not, run a live test on the sitemap with the URL Inspection tool:
  1. Specify the complete path to your sitemap by copying the path prefix from “Add a new sitemap” and add the submitted sitemap’s relative path, for example: https://example.com/sitemaps/mobile/sitemap.txt. Use the values copied from the report in order to guarantee that you are testing the same URL that Google is using.
  2. Click Live test in the URL Inspection tool. This should give you information about whether the sitemap exists and can be fetched by Google.
I see you are using a yoast plugin - so depending on the additional information you get from the GSC
you may find this useful Common XML sitemap errors • Yoast
