Sitemap.xml doesn't work
bbnaturalproducts.epizy.com
bbnaturalproducts.epizy.com/sitemap.xml
Every time I uploaded the file xml and then enter the url on google, it tells me that it is not found, what can I do?
Yes this is a very common issue.
Well I would like to tell that this issue does not relates to InfinityFree.
Google is deprecating the use of sitemaps very soon.
So they are going to use Index APIs that’s why this is common.
do you know a way to solve it? thanks in advance.
We can’t do anything.
But the issue is resolved now from google’s side :slight_smile:
