Hi,
please, can I download SLiMS (Senayan Library Management System) a free and open source Library Management System, on free hosting? Because I get error concerning MySQL
The following errors were found :
Could not make the query numbered : 21
MySQL Error No : 1064
MySQL Error : You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘json DEFAULT NULL, r int(1) NOT NULL DEFAULT ‘0’, w int(1) NOT NULL DEFA’ at line 7
Not quite sure if this will work here, that software says it needs PHP version 5.7, and that is not supported on free hosting. Premium hosting does support it though.
version 5.6.48-88.0
You can use this library system if you want (It is online, but you can embed widgets on your site)
