One of the great features of FileZilla is that it can use multiple connections to upload multiple files at the same time. Since FTP is heavily affected by latency (generally more so than bandwidth), this usually helps to improve performance.
Can you try to increase the number of simultaneous connections in Filezilla? And can you check what that does to the speed (in total and/or per connection)?
Yeah I can try this, though I’ll see if this is possible to do in Dolphin because it’s my system file manager and it’s way more integrated with my operating system. But if I can’t find it, I will try in FileZilla.
It’s also worth noting that I have a ServerPro server (I game hosting service) for Minecraft and have no issues with upload speeds with that using my file manager
Close the “Site Manager”, then click on “Edit”, then on “Settings”, on “Transfers” and set the “Maximum simultaneous transfers” option’s value to whatever you want from 1 to 10, then save the changes.
FileZilla is probably the best cross platform FTP client there is. It’s very fast and very powerful. Many other systems can do FTP, but none of them can do it quite as well as FileZilla.
The connection limit is set through the Settings, not the Site Manager.
My guess it’s that it’s either an IO issue on the FTP server or a problem with the latency or throughput between your computer and our FTP server. Playing with the number of connections might give more insight about which of those things it could be.
If you would like to help find out what it could be, could you share more observations of what changing the number of connections did to the performance?
