Hi there
i tray to install softaculous php but a message is showing to me
The following errors were found :
An installation already exists at http://domain.xxx as per our records. To re-install the application please uninstall the existing installation!
Hi there, Welcome to the Community,Please uninstall the installation which you previously installed. It can be done through Softaculous.Check the top right area to find all your installations and delete it
hi there,
i try to install new stuff , but same messages , also i check for my apps there’s no things to un install
Can you please post a screenshot of your all installations.
hi soundar
please find the screenshot
Please tell us your domain so we can help.
I get a HTTP 500 error, which means you’ll have to read this:
thank you
this error HTTP 500 error is fix but by delete htaccess , the Alter PHP did not worked
update
i think i must limited to one App , and i removed the joomla and i try to install this one but when it reach 95% it stop
Hello, I believe that InfinityFree has been busy today, as previously i believe the forum went down. Generally, there is nothing you can do.
Admin
August 25, 2020, 3:44pm
#15
That’s news to me.
But I do know that iFastNet is doing maintenance on Softaculous right now (has to do with the new WordPress version too), which may explain some of the issues.
hi i have this issue ( Inodes Used 100%)
Inodes Used 100 % (50015 of 30019)
there is no thing to delete !!!
Yeah, I read on another topic that some time ago people got a CloudFlare issue or something
system
Closed
September 9, 2020, 11:01pm
#19
