I went to login to my wordpress website and it showed me an error message, so I thought to review the install in Softaculous. When I try to enter the area I get the following error message:
It appears your account has fully used it’s inode allocation, you will need to delete files to reduce inodes before the script installer will work, or upgrade to premium hosting where we offer over 400,000 inodes !
Not sure if this is just me or something I am overlooking.
no need, I already deactivated and will try to redo it all, the saddest part is that there was no answer to what caused it and no way to find out what was causing it.
but i guess if I can not get it to work, I will just need to try another service elsewhere.
Infinityfree has a limit of 30k inodes per account. You hit that limit, mostly due to huge plugins or thems? SO there is an answer, delete files, wait for few hours and then login to wp.
