I tested social network scripts and I noticed that Jcow doesn’t work. I installed jcow, I visited a website and I saw a blank page. Does it happen with other scripts.
It could happen with other scripts, not every script offered by Softaculous is guaranteed to work on our service.
That said, I’m not aware of any issues related to Jcow. Do you still have the installation up somewhere I can check whether it’s a compatibility issue or just a configuration problem?
Some scripts on softaculous are not guaranteed to work on infinityfree, because some scripts may require Perl, ruby and etc… And those ruby required scripts or other are not supported on infinityfree!
You may want to upgrade to premium hosting to make it works! ?
