Hi.I upload my nextpost script.and when I start process of installation fill the blank then press installation I faced with something went wrong! It seems that application is already installed! error.I delete my database and then upload my code again but it isnt solve. I asked others install it succefully and they say If youve get any error during the first installation, then probably something on server configuration is not correct. Please check your PHP error log, fix the error.
please help me to solve my problem and install the script.my site is http://next1.epizy.com/4.1.1/NextPost/nextpost[www.20script.ir]/
It needs the OpenSSL extension right?
I’m not sure if you can run it here.
@UnknownLolz
yes I think It need this feature.the site says
OpenSSL: PHP OpenSSL extension must be installed and enabled. This is required for secure data encryption. OpenSSL version must be 1.0.1c or above.
Outdated OpenSSL extension might cause several issues.
what should I do?
Social media auto posting sites are not allowed here, because they are often used to spam. Please remove that software from your account.
@Admin
tnx I didnt know this problem.would u please introduce a hostsite that compatible with my script?
