At epiz_32763840, the sql_mode is empty, i.e. not set to strict mode, i.e. it allows empty value for an enum field. I know it cannot be changed, but I expected it to be set to strict, as suggested in this other forum post:
I’m pretty sure that’s now how it works.
When the sql_mode
version is set to empty, it means it uses the default value as determined by the developers of the database system. We don’t customize this value because the default value is most likely to be what other hosting providers use too, so it offers the best compatibility with software and interoperability with other hosting providers. We’re not going to enforce our personal opinions on how to use SQL on our users.
Our database servers run MariaDB 10.3 so, as you can see in the link below, the default means that strict mode is enabled, and specifically the STRICT_TRANS_TABLES
option. And looking at the documentation, with this option set, enum fields do not allow empty values.
How did you come to this conclusion exactly? Did you just check the value of sql_mode
and assume that this would allow empty values in enums or did you actually check whether you could actually set an enum to an empty value?
In the reverse order. I first ran into problem with an enum field, then did research. It can be easily confirmed in phpmyadmin, just I am not sure at the moment if I can insert screenshots here.
Hmm, it seems you’re right. Interesting, the SQL mode setting is not what I expected and not what I would have put it to. Thank you for investigating this issue and telling us about it!
I’m going to talk to iFastNet to see if this setting is what they intended or if this is an error.
I haven’t reached out to iFastNet yet but I did do some additional investigation.
I tested various other database servers from different hosting providers. Not having strict SQL mode enabled seems to be fairly common. This may be caused by the fact that not all software can run with Strict SQL mode enabled (WHMCS comes to mind).
So it’s possible that this setting was actually done intentionally to enable support for scripts which don’t support Strict SQL mode.
In the end, I guess it means that you have to take extra care with your input validation and queries in PHP to make sure that no unsupported values can be entered in the database.
Hi i would love to talk on forum.
i never play with enum type, i saw at stack overflow enum is just for integer unsigned. I see you put z.
To learn about enum in mysql, please read the mysql doc, for example: https://dev.mysql.com/doc/refman/8.0/en/enum.html
Sure, I can live with that.
Thank you for looking into this and for all your great work here!
I saw. It is possible to enum field get null as value, index 0 is empty after NULL. So i still don’t find the error. Is it?
