In the past, I used Hostinger and Cloudflare seperately (so I could have HTTPS support).
Now I moved to InfinityFree (seems great for now), but I have some issues.
I tried setting up Cloudflare using the Cloudflare website, it is all working well, except SSL certificate. It tells me it’s invalid.
I paused (and even deleted) the website from Cloudflare as I noticed that there is a Cloudflare option in the cPanel.
Upon enabling that, I got the error:
CLOUDFLARE ERROR : Sorry there was a problem activating cloudflare for this domain or the email address [email protected], this is normally caused by the email address or domain name already existing on the cloudflare system.
So okay. I understand that it doesn’t work directly, I’d have to delete my Cloudflare account to use this option.
Anyway, since I deleted the website from Cloudflare and set the nameservers back to InfinityFree’s nameservers, I still get the same SSL certificate error.
Here you can check it yourself, I have no idea what is wrong and how to fix that, I assume that InfinityFree “forces” their SSL over the external one when I enable Cloudflare?
[SSL Checker](SSL checker)
