Configuration has been correct for SSL certificate and I have my domain name, but I am using SSL checker said my domain DNS configuration errors, my domain DNS configuration screenshot in the comments section, could you tell me how to configure the DNS
If you’re using your domain registrar’s nameservers, and those don’t support CNAME Flattening, you need to get the IP of your server by following the instructions present here, then create an A
record with as name your domain, as TTL 300
and as value/target the IP you have found by following those instructions. After that, create a CNAME
record with name www
, TTL 300
and value/target yourdomain
, where yourdomain
can be replaced with your domain, and a MX
, as value/target mx.epizy.com
and as priority 10
. If you don’t want to configure those records, you can just set the nameservers to ns1.epizy.com
and ns2.epizy.com
and have your website working again after some hours.
What sort of “DNS configuration errors” do you see? What do the error message say? Could you provide a link or a screenshot where we can see these errors?
