SSL approval "Not Ready"
I have made many SSL certificates using infinityfree but it is not working this time:
And the Cname record is there:
What is wrong?
Your record is not pointing to the correct destination:
The CNAME record is incorrect. Please follow this guide (Or the video at the bottom of the guide) for the correct steps.
The CNAME record should match the Destination. You can clearly see Current Destination and the Destination don’t match, which means you have a CNAME record, but a wrong one.
So you should delete the current CNAME record and create one with the correct destination.
